Monolith grinder: Conical vs. flat burrs - Page 2
In my case when I went to purchase the Monolith Conical I already had a Mazzer Major which is a large flat burr. The other driving factor was that the flat was still a dream in Denis mind at that time!
Suffering from EAS (Espresso Acquisition Syndrome)
LMWDP #586
LMWDP #586
- Balthazar_B
Already having a Big Flat commercial grinder was one of the reasons I decided on the Conical as well. At least so far as satisfying my palate is concerned, choosing between a Monolith Flat and Conical would be splitting hairs in the extreme. So in addition to diversity -- having an optimized single doser as well as a different burr geometry -- cost was the major driver for me.
- John
LMWDP # 577
LMWDP # 577
For pourover with African beans, is there more clarity with a flat?
Thanks everyone for the reply's so far. I'm leaning toward flat but the price of conical is a bit nicer.
I mentioned the gs3 bc I posted this in another thread and it got separated to here. I was trying to connect with the people who had posted that had the same setup, but I want everyone's thoughts. Even if it's about other grinders!
Everyone have a negatives with the monolith in general? It seems to be the perfect single dose grinder, which is why I'm gravitating towards it. I hate the retention on the lower prices ones.
If I had to nit pick a negative it's that I had to add some silicon washers to the portafilter stand to stop a buzzing noise I had. This is so minor that the point of posting this isn't to highlight a negative with it, but to highlight the sheer lack of them.
Regarding retention, I use RDT and see essentially none. Instead of removing the magnetic spout, I just kind of tap it while it's ejecting and no grounds are stuck. I rarely even use WDT anymore after the break in. It's the only grinder I've used where I can toss beans in the freezer with a grind number, (along with shot paramters) come back to it weeks later and still pours perfect. Other titan class grinders may do this, I haven't tested them all obviously. So if it's the sheer size of the burrs that give this ability, then other grinders may do this, but I didn't see any at the price point that focused on single dosing low retention and repeatability when adjusting.
Without a doubt, you should get a conical or flat.SilentDoom wrote:Ok ok. I know this is a loaded question with no right answer, but if I plan to get a gs3, which would you guys says I should get: conical or flat?
Rocky
- redbone
Flat for espresso.
Conical for P.O. and drip.
My 2¢.
My 2¢.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Hahahaa, my thoughts exactly, its like trying to make a decision between two ultra-exotic supercars based on features/performance, at some point you just gotta buy the one that speaks to you more and rest assured that either ones performance will be impressive.RockyIII wrote:Without a doubt, you should get a conical or flat.
Rocky
I have both and I suggest you get both.
Haha. I think the flat is prettier. Other than that you are splitting hairs.
I suggest the answer to your question is subjective and without an objective answer. Responses will come down to personal preferences.
- shawndo
Anything less than both is uncivilized
Darmok and Jalad at Tanagra
