Molykote 111 Lubricant Alternative that is H3 Rated
I was looking for an alternative to Molykote lubricant that is NSF H3 rated for direct food contact instead of NSF rated H1 for incidental food contact as Molykote is. I was wondering if anyone has tried this Edible Gel 57 that is H3 rated and manufactured by Slipstream in Britain: https://store.slipstreamlubricants.com/ ... 1464520905 If you have, what do you think of it as a substitute? Is there a different H3-rated lubricant you've tried? Note, I would rather not get into a debate about the safety or toxicity of Molykote.
- trumz
Maybe SuperLube has something... I personlly use it for steam wand valves.
https://www.super-lube.com
Thanks. I noticed that SuperLube does have an H3 rated one: https://www.super-lube.com/h-3-lightweight-oil-60004 My concern is that is "a lightweight oil" and I wondered if that wouldn't work for O-rings and group heads and such. Wouldn't something more viscous be required?
- TomC
in regards to the Edible Gel 57, Im wondering why they state "minimum shelf life of 12 months". What's the maximum? Does it go bad?
All good questions. I'm not sure. I imagine if it is a vegetable-based lubricant there is a potential that it has a limited shelf life. I wonder if anyone on HB has tried it.
- Jeff
I think you're going to be hard pressed to find anything more viscous than mineral oil with an H3 rating.
https://info.nsf.org/usda/psnclistings.asp -- select H3 from the categories.
Some general information at http://media.noria.com/sites/WhitePaper ... 200901.pdf
Edit: https://www.newfoodmagazine.com/article ... r-fiction/ suggests that there are still some technical issues, including stability, with "truly food-grade" grease
The author of the article linked last makes having a viscous vegetable-based H3 lubricant sound difficult but not impossible. I'm hoping there is one out there that works.
