Mahlkonig EK43s worth it? - Page 3
- Terranova
- Supporter ❤
I don't agree often with you, but in this case I do.ds wrote:0.010 µm is 0.00001mm which is a ridiculous tolerance that very, very few in the world would possibly be able to achieve let alone measure. Aerospace/high precision tolerances are at and below say +/- 0.007 mm and even that is too much for a grinder.
Denis got some numbers wrong.
You can only measure it on a lathe machine, but there you can get it better than 0,01mmds wrote:I height doubt claimed tolerance of less than 0.009mm on flatness. How is that measured and with what kind of instruments? Run-out maybe, flatness over 4" area, I doubt it.
This one was measured before getting it revised.
http://www.youtube.com/watch?v=lPuD3Otxn5c
Yes you can, but you cannot go over 250 mph with a Bugatti when the engine inside is from a Yugods wrote:You can't put Bugatti Veyron tires on Yugo and go over 250 mph with it...
Which is exactly my point. You are not going to run that part in lathe and grind coffee on a lathe.Terranova wrote: You can only measure it on a lathe machine, but there you can get it better than 0,01mm
- Terranova
- Supporter ❤
This doesn't make sense to me, or I just don't get it.ds wrote: You are not going to run that part in lathe and grind coffee on a lathe.
The more accurate all parts, the less tolerances where all the tolerances meet - at the burrs.
So it is totally OK to have all parts as accurate as possible.
If there is a lets say 0,03mm run out at the shaft, it doesn't mean that all other parts can also have a 0,03mm run out because at the burrs it is an addition of all parts which makes it much worse than 0,03mm.
- Denis
I fked up the measure unit.
The gauge I measure with it's 0.01mm and doesn't move when I get the grinder aligned. This means it has unde 10 microns play. This is enough for me.
