Looking for white 12oz frothing pitcher
Hello, I'm looking for a 12oz white frothing pitcher in an attempt to match my upcoming setup. This will be my first foray into frothing and I'm hoping for input on a quality built pitcher...
I've always had good results using pitchers from a company called Slow Pour Supply Co.
https://www.slowpoursupply.co/collections/latte-art
Thanks. I'm checking now!
Nice selection of pitchers. I've added some to my watch list. I'm also curious about the Brewista Nasty Jug.
- BaristaBoy E61
You might want to consider this. It's probably made by Motta for Rocket. 12oz is really small!
https://www.wholelattelove.com/collecti ... atte-white
- Randy G.
Not white, but Espro Torroid pitcher.
www.EspressoMyEspresso.com
* 21st Anniversary 2000-2021 *
I think you're right. I likely need to go larger because I didn't realize the space I would need for frothing. I plan to froth about 8 ounces of milk.BaristaBoy E61 wrote:You might want to consider this. It's probably made by Motta for Rocket. 12oz is really small!
I use the 17oz pitchers from slow pour to steam milk for a 10 oz latte (2 oz espresso; rest milk) and it's a good size to leave room for as much or as little microfoam you want to add.
Which drinks will you be making? In my experience a 12oz pitcher (I have the fellow eddy, it's fine, but unspectacular) is perfect for a cappuccino (4oz of frothed milk) or a small latte (~6oz of steamed milk). For a larger latte, or multiple drinks, something like 16-18oz would likely be better; for anything smaller, like a flat white/cortado/machiatto, I find 12oz a bit hard to reach the milk, at least with the angle of my steam wand, so I use a small 8.5oz motta pitcher, which I love.clokwork wrote:I think you're right. I likely need to go larger because I didn't realize the space I would need for frothing. I plan to froth about 8 ounces of milk.
Most mornings will just be for me. I usually make a cortado or 10oz latte (similar as stated before using 8oz of milk). I have a strong feeling my wife will slowly want my espresso drinks with milk as she weens off her nespresso. I want it destroyed so I can steal the counter space.
