Levering up - machine suggestions - Page 3
- mrgnomer
Now there is a deep rabbit hole.pizzaman383 wrote:You should build your own lever!
You can pick your favorite lever group and build exactly the machine you want!
Kirk
LMWDP #116
LMWDP #116
- pizzaman383
- Supporter ❤
Don't I know it!!
Curtis
LMWDP #551
LMWDP #551
- drgary
LMWDP#308
LMWDP#308
- mrgnomer
Nice work, Curtis. Yet again a sweet song calls from a near by rabbit hole. I must turn away. The honey do jar must be emptied first.
Kirk
LMWDP #116
LMWDP #116
I've been getting used to the Robot. The more I use it, the less I want to add milk. When I do, the LM GS3 becomes my steamer .
That is one very expensive steamer!!!
Julia
I'd love to hear more about the dimmer mod on the Strega! Shoot me a pm if you wantbostonbuzz wrote:I have had a Strega for about 8 years. I PID'd the grouphead, installed a pump dimmer for pre-infusion, and a brew pressure gauge. I think it's a great machine with these additions. My curiosity wouldn't let me NOT do this to it.
These days, low pressure, different pre-infusion pressures, etc. are all the rage. The strega is aging very well.
You keep the pump low and pre-infuse at 3 bar, and then release the lever and the shot is much lower than 9 bars. You let the pump come to full pressure and when the lever releases you have a high pressure shot. You always have a declining pressure, but you can change the preinfusion pressure and starting lever pressure before the decline.
- bostonbuzz
There are a few threads about it. But it's the same as any vibe pump dimmer mod.
LMWDP #353
I've had quite a few levers but to me there are two machines that stand out tastewise.Ponte Vecchios and my latest the Lambro.
Here are two espresso's with my Lambro. One pull,two nice ristrettos/espressos.
Soft tasting espresso.If no waterline is available my pick would be a Ponte Vecchio.
But you might not like it.These advices are pretty useless since not everybody has the same taste in espresso.
