La Marzocco GS/3 vs. Slayer
Hello everyone. I'm looking to upgrade from my Breville Oracle to either a GS3 or Slayer. Would the vibrating pump in the Slayer take it out of the running; the vendor suggested that because of the vibrating pump, the Slayer is an inferior machine. My impression( and please correct me if I'm way off, just a novice) is that the vibrating pump allows for a longer pull/dwell at a lower flow rate which would be well suited for the single origin lighter roasts.
- spressomon
Slayer utilizes a gear driven pump.
No Espresso = Depresso
- russel
Either you misheard, mistyped, misunderstood, or you need to find a different vendor.Redphu wrote:the vendor suggested that because of the vibrating pump, the Slayer is an inferior machine.
russel at anacidicandbitterbeverage dot com
Russell,
Thanks for the reply. Could you elaborate further please. Do you have first hand experience. Thanks.
Like the prior post states, Slayer does not use a vibrating pump.
-- Richard
- EricC
I have firsthand experience with a Slayer and I can tell you it does not have a vibratory pump. It has a gear pump. But one does not need firsthand experience to know that. On this forum it's common knowledge. But if u want to know about those 2 machines there are review articles here on HB for both. If I were you I'd read both of them first then come back and ask questionsRedphu wrote:Russell,
- CarefreeBuzzBuzz
I can't compare because I don't have a GS3. I do know there are people here who have modified their GS3's to make Slayer like shots. I can confirm that you have lots of options with the Slayer. Haven't yet begun to figure it all out after a few months. So search around the threads here and you will find those and get insight into how and why and that may help you decide.
