I need help to find a espresso grinder pls!
Hello! I just bought a LaRocca Alin coffee maker for home use (espresso only), and I'm looking for a grinder. I've been thinking about these alternatives:
HeyCafe HC-600, https://www.heycafe.com/system/files/He ... tsheet.pdf
HeyCafe Titan II, https://www.heycafe.com/system/files/He ... tsheet.pdf
Eureka Zenith 65 Neo, https://www.eureka.co.it/en/catalogo/pr ... /1/41.aspx
Cunill Tranquilo Tron, https://www.cunill.com/cafe/detalle_pro ... 4U5HuyZO3I
I would appreciate if you could recommend which one is better, or comments on which one to choose!
Thank you very much
Thank you very much
- Jeff
Would you let us know a bit about your tastes in espresso? What is your budget? Do you plan on changing coffees or grind settings often?
That's an interesting list. I don't think I'd recommend any of those against options available in the US.
Hi!
It is mainly to learn how to prepare espresso and cappuccino. Those are grinders that are used and are quite cheap. I live in Chile and those are the only ones available to buy. (I'm sorry, but my English is not very good) thank you very much!
It looks like you have very limited options. If these are used, you might want to consider their use history, like were these used in a home or commercial setting. If there were used in businesses, were those busy cafés or something like a restaurant that would occasionally serve coffee? Given your location, you should consider availability of parts and service.
Hi! Thanks for u answer. The use of the grinder is only home and the grinder are new.
Cheers
Cheers
- Jeff
I do not have any direct experience with the grinders that you listed.
I would also look for a Mazzer Super Jolly or a Eureka Atom 75. The Super Jolly is a well-respected grinder that it looks like may have inspired the HC-600. Hey Cafe is a Hemro brand. While it may not be as sturdy as their Mahlkonig or Ditting grinders, it at least comes from a parent company that understands grinders. Eureka grinders are also well respected here.
The Cunill is "light duty" and only has 60 mm burrs. I would not pick that one because of concerns over how well it survived in a commercial setting and its burrs. I am guessing, with no proof, that the burrs are not as good as the 64 mm burrs in the Super Jolly or Hey Cafe machines, or those in the mid- and upper-range Eureka grinders.
How much are these options costing you in usd? Buying a Chinese grinder off aliexpress may not be ideal, but it might be an alternative to consider depending on if currency conversion, duties etc balloon the cost of more traditional choices.
