Help me pick my next espresso machine, please! - Page 3
Ok if its the tumbler it makes sense now. Does the opening at the bottom of the tumbler fit exactly 58mm? I would have thought it would be smaller than 58mm to make sure all the powder is emptied into the portafilter. If the opening is smaller than 54 mm it could still fit a 54mm portafilter. I you measure it, you could see if that is the case.brooksie967 wrote:You make good points for sure!
The magic tumbler on the key fits a 58mm portafilter. Haven't seen anyone with an adapter for 54mm.
I have a made in China blind shaker tumbler that can fit most sizes of portafilter that functions in the same way that the weber tumbler does, and I like using it. I have no idea if it makes the coffee better distributed, but I have made it part of my routine along with wdt.
LMWDP #729
- JB90068
- Supporter ❤
I would think that using a collar on a 54mm PF would allow you to use the blind shaker from either the Key or EG-1.brooksie967 wrote:The magic tumbler on the key fits a 58mm portafilter. Haven't seen anyone with an adapter for 54mm.
Well I'm a proud owner of a rocket r9 one with wooden panel upgrade kit! Slawek at idrinkcoffee has this as an open box deal for $3000 off retail. Needless to say I'm ecstatic! Machine should be here in a week!
