hi, what is a good starter grinder for brewing coffee in the bonavita immersion dripper? is the baratza encore good enough or should i look for something else? thanks.
toddy2348
Postby toddy2348 » Oct 13, 2018, 3:13 pm
I plan on only grinding coffee for 1 or 2 cups at a time. Are there any inexpensive grinders (electric or manual hand) that someone can recommend me? Thanks.
redbone
Postby redbone » Oct 13, 2018, 5:09 pm
I've had good results with my Bonavita immersion drippper using a Capresso Infinity grinder. Offers a simple timer. Comes with either a plastic or stainless steel housing.
Between order and chaos there is espresso. Semper discens.
Rob LMWDP #549
toddy2348
Postby toddy2348 » replying to redbone » Oct 13, 2018, 6:42 pm
what grind setting do you use for the bonavita immersion dripper?
redbone
Postby redbone » replying to toddy2348 » Oct 13, 2018, 7:02 pm
Here or around here is the setting I use for Bonavita. Placed a screw on the lid ever since the my "tried to fill hopper with lid on twice disaster".
Rob LMWDP #549
toddy2348
Postby toddy2348 » Oct 13, 2018, 9:29 pm
ok bought it, will try the same setting as you.
redbone
Postby redbone » replying to toddy2348 » Oct 13, 2018, 10:23 pm
Your settings may vary slightly. You will just have to play with the dose. Be sure to use chlorine free water. All the best. Don't forget to report back.
