ECM stainless steel tamping station
- Derryisreal
Hi guys, I bought the ECM aluminum tamping station and I find the build quality rather disappointing - the top edge is very easily scratched, the unit is too light to stay steady, it is nonadjustable (no adjustment screw). Almost by chance I found out ECM makes a much better version of this station - stainless steel, much heavier and with a height regulating screw.
However, the only place I was able to find it is here:
https://idrinkcoffee.com/products/ecm-a ... ng-station
The price is quite high!
But seems like non of the US vendors carry it or are even willing to order it. So I might have to pull the triger and buy from Canada.
On another note, idrinkcoffee.com caries stainless steel ECM portafilters, these I also wasn't able to find in the US
Just thought I'd share this, in case someone is interested.
Light roasts are to me what garlic is to vampires.
- Jeff
Even with the CAD / USD conversion, yes, that's a bit steep.
Gilberto ("Mr. Bravo") makes one similar, which I would assume is up to his usual high standards in design and execution.
https://www.bravocoffee.com.br/suporte-de-porta-filtro
I've seen various wooden ones of various (generally poor) quality.
Reaching out to cannonfodder is another option: Custom Wood for your Espresso Machine
- Derryisreal (original poster)
Thanks Jeff, these look interesting, I will check them out!
- BaristaBoy E61
If I were paying top dollar, here's where my money would go:
https://www.tidaka.net/Tamper/Tampersta ... -158.html
On the other hand, this is what is serving us quite well:
YMMV
YMMV
Nice looking cube, but I am not a fan of aluminum, even the best kind, and it doesn't have the mass to keep steady. Anyway, I broke down and bought the ECM stainless . Also bought the ECM stainless portafilter, since it doesn't seem to be available in the US. Now all that's left is the Puristika!
- slybarman
- baldheadracing
The spouts don't touch anything.
I usually use mats for bottomless portafilters, and stands for spouted portafilters.
- slybarman
Not that much. I have both. It feels slightly more solid not hanging off the edge of the counter and it's slightly less in the way. If I didn't get the tamping station free, I probably would not have bought one.jgood wrote:What's the advantage over a tamping mat?
- JB90068
- Supporter ❤
I have one of the SS ones and it is worth it. Just checked WLL where I got mine and Clive. Seems that they no longer carry the SS version. It's unfortunate too bad because the heavy version is solid and with the O-ring on the bottom, doesn't move around.
