Cheap coffee scales - any to beware of? - Page 2
I went through several cheap scales and they all had problems: response time for some, drifting for others, etc. Finally gave up and bought an Acacia Lunar. No problems since.
Maybe I had bad luck with the cheap ones, but happy now.
It works fine for me. It is slow to respond compared to the $200. scales. I just have the anticipation figured out and can get within .2 g of my target yield most times. Honestly, I don't taste much difference +/- .5 g.cebseb wrote:How do you like your brewista? I had one previously but was very frustrated with its response rate.
Not beware of, more like be aware of.
For the last year, I've been using a Greater Goods Digital Pocket Scale. It's a no frills ~$15 scale with 0.1 gram precision, 750 g capacity, and fast enough response. It's super slim and is probably great for machines with low cup clearance...think Gaggia Classic. Definitely low cost and high value and totally worth it.
https://www.amazon.com/dp/B07SJTXGN7
For beans I got a jewelers scale off eBay for $7 that has lasted years. Handy for small stuff.
My baking scale was an $11 amazon.com/Ozeri-ZK14-S-Digital-Multifunction-Kitchen/ which does well for coffee
now <$10
I want one with a timer now
I know I may be buying twice, but it lets me know what features I really need , sort of proof of concept.
I throw a piece of plastic over it when exposed to the water, since some of my portafilters drip and spray.
now <$10
One more jolt, Warden. He's still twitching.
Is the flow rate display in the app easy to read? I have the Timemore Black Mirror Nano and the flow rate display updates too frequently (about 10 times per second), making it difficult to read while pulling the shot.cebseb wrote:$25 Bluetooth capable scale! I have it and it's been rock solid. Response time is fast.
Reflex 500g / 0.01g Digital Pocket Wireless Smart Food Kitchen Scale Grams and Ounces USB Rechargeable, Portable, Accurate, Metal Stainless Steel Surface, Keto Calculator, Baking, Counter, Reloading https://www.amazon.com/dp/B009LCM8YY/re ... UTF8&psc=1
- Supporter ★
For those that have the Lunar and perhaps did not read the warranty, the scale is under warranty for 2 years including water damage. States so on the acaia webpage under the scale description, but does not mention it in the manual.LewBK wrote:Even the Acacia scales says, "water resistant," not "water proof" so spilled coffee or water can still damage them.
Screenshot from webpage...
- Jeff
The things I check with a cheap scale before I buy it or when I get it from a vendor that allows "Free Returns" are:
* Does it use AAA or AA batteries so I can use Eneloop rechargables (no coin/button cells)?
* Is the auto-shutoff time sufficiently long, or can be disabled?
* Can the scale be calibrated?
* Does a hot cup cause the scale to drift excessively? If so, does a silicone or cork coaster "fix" it?
* What is the sensitivity? If I add 0.1 g to the platform, does it reliably increase a division?
* Is it reasonably linear? If I put a couple hundred grams of weight on it and then add a 50 g or 100 g cal weight, does it go up by that amount?
* Is it reasonably fast? If I put a weight onto the platform, how long does it take to settle down?
I've returned a couple over the years as they've miserably failed one or more of those tests. I don't remember which ones.
