Breville Smart Grinder needs replacement after 8 years
coffeeguyCT
#1: Post by coffeeguyCT »
I really like this thing but I'm now regularly getting a high pitched whine and no rotation of the burr, suspect stripped gear or other driveline issue. I have a 3D printer and usually fix all my own stuff but just don't have the time now. I suspect I'll order a new one but figured I ought to ask if anything else in its price range is worth a look? I use it with my similarly long serving Gaggia Classic.
Thanks
Rus
luvmy40
#2: Post by luvmy40 »
Other than a quality manual grinder, you're not likely to find anything as good, much less better than the SGP in the $200 price range. The fact that yours lasted 8 years is heartening. I had decent results with one short term but had no long term information.
La Marzocco · Home: customized for espresso aficionados
Sponsored by La Marzocco · Home
TomC
#3: Post by TomC »
coffeeguyCT wrote:I really like this thing but I'm now regularly getting a high pitched whine and no rotation of the burr, suspect stripped gear or other driveline issue. I have a 3D printer and usually fix all my own stuff but just don't have the time now. I suspect I'll order a new one but figured I ought to ask if anything else in its price range is worth a look? I use it with my similarly long serving Gaggia Classic.
Thanks
Rus
Where-about in New England are you? I'd assume Connetticut.
[FS] 2020 Baratza Sette 270wi (Boston)
coffeeguyCT (original poster)
#4: Post by coffeeguyCT (original poster) »
CT Indeed thanks for the link.
coffeechan
#5: Post by coffeechan »
I'd look into the entry level Mignon Manuale/Notte too if you can live without a timer. It'll be a step up in build and grind quality.
#6: Post by coffeeguyCT (original poster) »
I've found the repeatability the #1 thing. That and grinding straight into the portafilter. Otherwise its all just too much work for an amateur like me.
Despite my complaining I am going to open the damn thing up. It just violates some core principal of mine not to at least try to fix it.
Jeff
#7: Post by Jeff »
After eight years, the burrs in a light-duty, home grinder may be due for replacement. At least last time I looked, you couldn't buy both the upper and lower burr for that grinder.
CafelatStore: home of Cafelat products online
Sponsored by CafelatStore
luisguilherme
#8: Post by luisguilherme »
If repairing is your thing, I think you can't go wrong with a Baratza, unless you require much more quality (but IMHO a Baratza Sette 270 is a step up in quality from the SGP; The Wi has more tech, so more things to go wrong, though)
slipchuck
#9: Post by slipchuck »
Bezzera bb005 around $360US
Randy
#10: Post by coffeeguyCT (original poster) »
Turns out the issue was the gear driven directly by the motor. Plastic teeth wore or melted.
