Hello guys,
There is any original 54mm bottomless portafilter to my machine?
I bought one from 'Aliexpress' and it awful.
Bottomless portafilter for Breville Barista Pro
- slipchuck
I have this one. Not OEM but fits and works great. https://www.cremacoffeepro.com/products ... ortafilter
The brewing is the same like the original portafilter ?
The one that arrived from 'Aliexpress' just "spit" the coffee after 4secs.
A bottomless handle generally doesn't change extraction. As it seems you've found, it can reveal things hidden away. I would guess your extractions have been "messy" all along. Though picture-perfect extractions don't mean great espresso and vice versa, getting rid of spritzers and dead spots usually helps.
How are you grinding your coffee and prepping things for a shot?
There is probably be something simple you can do to improve things
(I'm assuming you're using the same basket. It is possible that if the import handle had a basket that it was different than the one you were using before.)
