Best Value Flat Burr Grinder?
Hi Folks,
I am looking for a flat burr grinder that will deliver good value in terms of grind quality/uniformity and single dosing. I currently use a Kinu M47 Traveler as a starter grinder paired with a Robot but have figured out I like lighter roasts and would like to upgrade my grinder.
I don't want to pay for a monolith flat, even if I could get ahold of one. Any recommendations on a grinder that will give good value and is more affordable than a monolith?
Thanks
Thanks
Read this thread beginning to end: Baratza Vario owner experience
Cliff notes: great durability, easily aligned to Monolith specs, very good single doser, produces light roast grinds fine enough for flow profiling on par with an aligned Super Jolly with SSP burrs (this last bit you should re verify with Jake_G as he is the one with the Vario and the SSP Super Jolly, able to do direct comparisons).
-Peter
-Peter
LMWDP #553
I will be using the grinder almost exclusively for espresso but it is a plus if it is good for pourover as well.
Jake makes only espresso and only light roasts. Read the thread. Ask questions if any remain. You can swap between brew burrs and espresso burrs at will, without messing up the alignment.
-Peter
-Peter
LMWDP #553
Thanks Peter, that is a very interesting thread, will look into it.
By way. Sorry if I came off blunt. I was hurrying out the door. Between Jake and I we can answer a lot, including in-cup comparisons with legends like Monolith Flat (which I also have), well known value grinders like Niche Zero, AND Jake's aligned Super Jolly updated to today's SSP burrs. I know you wanted single dosing, which the Super Jolly is not good at, BUT at the very least you can shake Jake down for some taste comparisons, which he is both good at, and honest.
-Peter
-Peter
LMWDP #553
