Bean Counter Shootout
- BaristaBoy E61
I hate the drudgery of blending single doses myself at home and am wondering if anyone has experience or thoughts about using a bean counter to reduce the time, effort and boredom of this tedious task.
I'd love to hear your comments and thoughts as to whether a bean counter would actually save time and which one might be the pick of the litter and why.
TNX
TNX
- JB90068
- Supporter ❤
I'm with you and know your pain. At this point, I would lean towards the Acaia Orion Mini.
I have the Acaia Orion and use it with WW commercial tubes (you need at least 2 funnels tho, I have 3). It really saves time
LMWDB #691
LeverHeads group on Telegram
- BaristaBoy E61 (original poster)
Is there a reason that you chose this bean counter over the Weber? By what percentage or factor would you say that it saves time?
Would you buy it again?
TNX
TNX
1- Orion's hopper holds more beans
2- WW's tubes with funnels on top fit below the Orion
3- saves time when you're filling the single dosing tubes this way instead of manually filling them
Would I buy it again? Yes if it was cheaper. I think it's overpriced for what it does/ when in use.
LMWDB #691
- JB90068
- Supporter ❤
How accurate is it? I've heard it can be off by .4g per dose?
This is what I do. It is as accurate as the Orion's that I had but a whole lot faster. http://www.youtube.com/watch?v=qiEBU36bHOY
Most counters will be out by up to 0.3 grams but remember this is not a ground coffee weight, we are weighing whole beans so it's impossible to weigh to a whole gram unless your beans are somehow miraculously all of a uniform weight that divides neatly into a round number
Pouches are then vacuum sealed. Discarded plastic pouches are recycled via the local supermarket.
A little obsessed.
You are right. It's not accurate but I fill the tubes to the top anyways (helps keeping them fresh)JB90068 wrote:How accurate is it? I've heard it can be off by .4g per dose?
LMWDB #691
+ or - .4g?
Can be either. Refer my post above: we are talking about whole beans, not ground beans so a +/- is inevitable.
A little obsessed.
