Advice on buying first good lever
Been drinking pour-over for a long time and recently got into espresso. I'm currently using a Lido e/t and a Rokpresso that I bought years ago and dug up from the basement. I can get passable shots from the Rok, and the quality has definitely improved since I got the lido, but I am ready for an upgrade. Unfortunately I am a poor grad student so my budget is around $600. I don't use milk so a steamer isn't necessary, and I only make 3-4 shots a day for myself. With this in mind I've seen a few choices that would fit
Cafelat Robot
Used La Pavoni
Flair
And Streitman CT1 (obviously way over budget, but it's an absolutely beautiful machine and if it pulls as good as it looks I'd be willing to save for a year or so/ wait for restock)
Also I will be using a wide range of beans (I roast with a behmor and I am fond of experimenting)
Any advice is greatly appreciated
Cafelat Robot
Used La Pavoni
Flair
- happycat
Best bang for the buck:Word_salad wrote:Been drinking pour-over for a long time and recently got into espresso. I'm currently using a Lido e/t ... poor grad student so my budget is around $600. I don't use milk so a steamer isn't necessary, and I only make 3-4 shots a day
Flair classic signature with second portafilter and tamper
PID kettle
Good to go for probably half your budget. Spend the rest on coffee.
LMWDP #603
- pGolay
I tried a Flair for a while and while I could make good coffee with it, the general fussiness of the process was just a bit past what I was willing to deal with on a day to day basis. I would guess the Robot is similar, and the ROK a step or two more fiddly, in my experience (I borrowed one for a week or three before the Flair). Hence, the CT-1 in my kitchen and the dent in the savings.
-PG
I do have the bonavita variable goose neck kettle which has been great. The only think I worry about the flair is it won't be a huge improvement over the Rok and I'll be looking for something new in a year.happycat wrote:Best bang for the buck:
PID kettle
Plus I'm getting green coffee for $6-8 a pound so that has never been a huge expense
- happycat
use the search function on HB and you'll find comparisons
Like this
User Experience: Flair Espresso Manual Lever
it's a good idea to search first, figure out and state your challenges and criteria, then ask focused questions. just like the process of setting up your thesis proposal.
Like this
LMWDP #603
- redbone
You can get a refurbished VAM or early Caravel for your budget. Currently using one on my lever rotation. Plenty of help available here if you want to refurb yourself. Many parts still available such as elements, baskets, seals and gaskets.
The Strietman CT1 @$2K+ is based on a VAM/Caravel.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
+1redbone wrote:You can get a refurbished VAM or early Caravel for your budget. Currently using one on my lever rotation. Plenty of help available here if you want to refurb yourself. Many parts still available such as elements, baskets, seals and gaskets.
Hands down best bang for your buck for straight espresso - I use one in my office. You can easily swap a European 220v element with a 110v for under $50. The boiler and piston are stainless steel so you know it is built to last, and they are easy to service and can be completely disassembled without any (special) tools.
LMWDP # 606
- drgary
Our in-depth reviews help with questions like this and give you a good sense of features and workflow. The reviews also link to user experience threads.
Cafelat Robot Review
Flair Espresso Maker Review
Flair Signature PRO Review
LMWDP#308
LMWDP#308
- spressomon
All good recommendations. FWIW, I love my EspressoForge. I have pulled hundreds of shots using it mostly while camping & mobile applications but also at home when I want to pull a different bean than what I have my main equipment set for. Super versatile. Simple, heirloom quality with only 2 wear items: 2-same size o-rings available anywhere (replace every 500 shorts or so). Easy to get thick syrupy shots or layered...all up to the person pushing down on the piston.
Apart of a recent dirt camping remote 4x4 of Utah a couple mornings I cranked out 15+ cappas using the 'Forge and a stove top Bellman with my MG-1 Grist for grinding duty. All went fine and folks were pleased .
No Espresso = Depresso
There seems to be a consensus about the shot quality and consistency you get out of a Robot. Higher volume is also easier to achieve compare to a Europiccola. At 3-4 shots per day, a Robot would be ideal since there is no warm up time needed nor any issues with temperature management if you end up making a few shots in a row.
One advantage a La Pavoni has over the other is the possibility to make a cappuccino for your guests which tends to happen when you have a nice espresso machine on your kitchen counter.
I do not own any of these machines but they are on my "I soooo want one of these" list. A V1 Europiccola from a collectible stand point (it also makes quite good coffee apparently...) and a Robot because they are beautiful performers.
LMWDP #592
