Needed: how to calibrate Nuova Simonelli Mythos grinder - Page 2
- CrabRangoon (original poster)
If you remove the case, you'll see that the knob/dial is actually turning a bit of a lengthy adjustment lever. You must make sure that the nut which tensions the lever against the knob, is properly tightened. Otherwise, if this has become loose, you will find that regardless of your input of fine/coarse settings the grinder will continue pumping out the same size grind.Munich wrote:Did you ever find a solution?
My Mythos is very reluctantly reacting to changes in the grind setting. A very thorough cleaning has helped somewhat, but the main annoyance remains.
LMWDP #505
