Grind Setting / Quantity Adjustments for Bonavita
Hey all.
Quick question. I'm using my Bonavita to make Red Bird's excellent Ethiopia Sidama - Shakisso. The cup is delicious but I thought maybe I can make it better?
I'm using a Breville Smart Grinder on the #6 setting (six clicks from left). I really like the blue berry notes in this coffe and would love to bring them out even more.
I usually do 30oz of water and around 48g of coffee (smart grinder set to 6 cups).
How would I bring out more fruity notes? Add coffee at the same grind setting? Keep coffee amount the same but more fine? Something else?
- Eastsideloco
Based on your water to coffee ratio (about 17.7:1), you definitely have headroom, so to speak, to increase the dose. I'd probably try that first.
Tried an extra 8g this morning. Made the coffee too nutty maybe even a little bitter, which totally removed any hint of blueberry.
I guess my next step is making the grind finer?
- drgary
You could sieve the fines to get a more even extraction and greater cup clarity. The bitterness may come from fines (dust) getting overextracted).
LMWDP#308
LMWDP#308
There is quite a bit of dust. What do you recommend using to accomplish this? Pasta Strainer?
- drgary
Something quite a bit finer than that. yakster found some sieving material at a paint store. TomC likes a #40 sieve, but they can be expensive. I visited someone awhile back who had a cone shaped strainer he used for beef stock, and that worked well. I just glanced at the mosquito screen on our window. Something like that would probably work but others in your household might object if you let flies into the house ...
LMWDP#308
LMWDP#308
- Eastsideloco
Maybe not. Grinding finer will likely increase bitter flavors as well. I might stay at the new dose and grind more coarse. (Then change course, if need be.)Bbdude wrote:Tried an extra 8g this morning. Made the coffee too nutty maybe even a little bitter, which totally removed any hint of blueberry.
Matt Perger's "best extraction" chart is useful in times like these:
Here's the blog post:
http://baristahustle.com/8020-method/
Thanks, all.
We've tried grinding more, grinder finer, grinder coarser, but have not tried grinding less. It's especially frustrating since we just went through a lb of this coffee a few weeks ago and it was great start to finish using the same settings we're using today.
E-mailed the roaster. Apparently since the beans are sun-dried naturally ... they're prone to tasting difference based on the weather and several other factors. This coffee has been pretty consistently different, and not in a bad way. I've tried to tweak it all over the place and I believe I had it right from the start so will just hope I get a different lot next time
