La Pavoni Millenium and Pre-Millenium portafilters
- Cafelatstore
- Sponsor
The wait is over for, in my opinion, the best improvement you can make to your La Pavoni Pro or Europiccola and that is to use a bottomless portafilter. And for the pre-millenium users we have the added benefit of a basket retaining spring, imagine that, a spring!
You can either buy as a basic naked portafilter, it comes with the basket spring and a bakelite handle as on current machines:
Or as the full set that includes the bottom plate and double spout so you can use as a regular portafilter and convert to naked within seconds. If you remove the double spout you also get a nozzle that works as a single spout.
Pre-Millenium (49mm basket older machines) are here http://www.cafelatstore.com/products/la ... ortafilter
Millenium (51mm basket modern machines) are here http://www.cafelatstore.com/products/la ... ortafilter
I tried to keep the look of the original portafilter, so we went with completely mirror polished stainless steel parts and the bakelite handle. All portafilters are tested in actual machines after I do the final machining/polishing and before shipping.
Since I imagine machine wear and gaskets have no doubt changed throughout the decades, the bottom plate can be rotated so that your double spouts can line up facing you, no matter where the portafilter locks in.
Paul
p.s. for those requesting Caravel elements, we have many 110v and 220v in stock, but untested as my Caravel died. Once I fix my Caravel next week, I will test new batches and open the shop again.
Paul
Hi Paul,
I am thinking about this for the Gaggia Factory (51mm), and another one for the QuickMill Achille 58mm (the Bosco/Londinium?). On the Cafelatstore it was mentioned all base plates and spouts are interchangeable....I assume the base plates won't be in this case?
- Cafelatstore (original poster)
- Sponsor
Yes only the 58mm's share the same plates. Spaziale, LP millenium and LP pre-millenium all have their own unique plates. We will try and make it clearer on the website.
- beer&mathematics
this is wonderful! Thanks for looking out for the lever people Paul!
Although I don't have a La Pavoni, Do you know if the 49mm Pf will fit the Bezzera family lever?
LMWDP #431
- CrabRangoon
Any plans to conquer the Cremina or Caravel PF on the horizon? I sure hope so, glad to see you continuing to expand to covering more lever varieties.
LMWDP #505
- yakster
After he does the Faemina.
-Chris
LMWDP # 272
LMWDP # 272
- Sponsor
Hi no plans to do the caravel, I thought Thijs in Holland was working on those. The Faemina market would I feel be too small, that would have to be a pre-order type thing and we would need a fair number to break even.
My order of a 49mm portafilter arrived today.
Couldn't decide on which spout to get, so I ended up getting both the mini double and the double.
Thanks for the prompt delivery and great service Paul.
LMWDP #537
- yakster
Understandable, I keep hoping that all the new Faemina owners will get us to the tipping point, but I may have a line on another solution, and if it pans out I'll post about it here on H-B.Cafelatstore wrote:The Faemina market would I feel be too small, that would have to be a pre-order type thing and we would need a fair number to break even.
-Chris
LMWDP # 272
LMWDP # 272
