Keep getting bitter coffee out of my Aeropress - Page 2
- drgary
Alan Adler, the Aeropress inventor, likes to home roast his coffee just into second crack. For that level of roast 175F is quite good. I have a dark roast from Red Bird that is slightly into 2C and it's good at 178F and bitter above that. I brew some Nordic roasts at 209F. Lower than that, they're sour. So what I'm saying is don't go by a strict formula but tune your parameters by taste. First of course you'll need a better grinder. If your grinder still puts out too many fines you could use a sieve to get the dust out.
LMWDP#308
LMWDP#308
Zoran wrote:So far, the "best" result I've had has been from following recipe, taken from the 1st place winner of the 2014 Aeropress championships... I used a thermometer to verify the temp of of the water is around 200F
That 2014 1st place recipe used 172°F water.Zoran wrote:The "original" recipe that came with the Aeropress said to use a brew temp of 175F but that sounded way too low with me, especially given the fact that every other recipe out there used normal brew temps.
hehe, I have really been wondering what you meant in the other thread comparing pharos and bunnzilla. You said 209 in that thread and really confused me for a minute! I wasn't the intended recipient of this information, but I will certainly consider it as I brew.drgary wrote:Alan Adler, the Aeropress inventor, likes to home roast his coffee just into second crack. For that level of roast 175F is quite good. I have a dark roast from Red Bird that is slightly into 2C and it's good at 178F and bitter above that. I brew some Nordic roasts at 209F. Lower than that, they're sour. So what I'm saying is don't go by a strict formula but tune your parameters by taste. First of course you'll need a better grinder. If your grinder still puts out too many fines you could use a sieve to get the dust out.
Thanks again for all the suggestions. I brought my temperature down on my last cup and it definitely helped so I'm going to keep experimenting with it. Also, I should have pointed out that these are not fresh beans, so that's probably a factor as well. Also, I did end up snagging a refurbished Virtuoso so when that comes later this week I should be able to control that part of the equation more.
