Rancilio Silvia malfunction/No water through brewhead
Wondering if someone can help. I bought a used Rancilio Silvia on E-bay(looks new-still has the laser sticker material on it). It was used. It makes steam but no water comes out through the brew head. I don't see any water being pulled in through the lines from the water reservoir. I took off the lid and the works inside look spotless. I don't see any leak or anything amiss. A thing of beauty, really. But alas, it does not work!
- heavyduty
I'm not very mechanically inclined, but maybe this will help: http://www.coffeeco.com.au/articles/repair.html
Have you taken the screen off to see if it needs cleaning?
Tomorrow came sooner than expected.
Paul
Paul
- erics
- Supporter ★
Remove the top cover and IMMEDIATELY disconnect one of the heating element leads until this problem is solved.
The pump MAY NEED a little priming with a "turkey baster" forcing some water into the pump's suction hose.
