Sample roaster advice pre 5k roaster purchase - Page 2
- millcityroasters
Not quite. BDL is taking a 1500 gram sample roast cost of greens ($6/500 gram = $18 /1500 gram) vs greens cost of 250 gram ($3) yielding a sample roast expense savings of $15 per roast. $6000 sample roaster cost / $15 per roast expense = 400 roasts to paybackCoffeeMan9000 wrote:Without a revenue assumption there isn't any amortization of the cost of the machine. This appears to be a calculation of how many roasts it takes to make the initial machine cost equal to the green cost.
Bryan is just starting out. He's got a chance to purchase a nice used USRC 5kg locally later this year and he's considering trying to learn how to roast on a some sort of an entry level drum roaster for fun now and potentially profit later. Huky, Quest, Hottop, USRC Sample roaster, Bella Taiwan or Yang Chia, TJ-067, Toper or Ambex 1 or 2 kg. (etc) just to get his coffee "chops."
If the "savings" that generate the amortization are 1,500g v 250g ( = 6,000/(18 - 3) = 400) and 1,500g v 500g, shouldn't the amortization be 6,000/(18 - 6) = 500? Perhaps I am missing something.millcityroasters wrote:Not quite. BDL is taking a 1500 gram sample roast cost of greens ($6/500 gram = $18 /1500 gram) vs greens cost of 250 gram ($3) yielding a sample roast expense savings of $15 per roast. $6000 sample roaster cost / $15 per roast expense = 400 roasts to payback."
- millcityroasters
I think BDL's premise was based in sample roasting 250 gram roasts with a USRC sample roaster vs 1500 gram roasts on a USRC 5 kg roaster.
I only followed his logic. It's up to Bryan to decide whether it speaks to his situation.
- boar_d_laze
Admittedly I did not use the term "amortize" in any of it's modern, accounting senses -- as for instance in "depreciating" intangible assets for tax purposes -- but in its older sense of extinguishing a debt through with small contributions. I'm sorry if I confused the financially sophisticated. Let's forget "amortizing" and try it again:
Clear now?
Rich
- Assume that "specialty" green beans average $6/500g; then
- The cost in greens of profiling a 250g charge is $3; and
- Of profiling a 1500g charge is $18; and
- Of profiling a 500g charge is $6.
- If developing a profile in Roaster A requires 250g of greens and costs $3/charge, and developing a profile in roaster B requires 1500g of greens and costs $18/charge, then how many charges must be roasted before the greens savings by using Roaster A instead of Roaster B amount to $6000?
- The difference in green costs between roasters is $15/charge. And the problem can be solved by dividing $6000 by $15; therefore
- The answer is 400 roasts.
- If developing a profile in Roaster A requires 250g of greens and costs $3/charge, and developing a profile in roaster C requires 500g of greens and costs $6/charge, then how many charges must be roasted before the greens savings by using Roaster A instead of Roaster C amount to $6000?
- Using the same reasoning as the previous example, we divide $6000 by $3; and
- The answer is 2000 roasts.
Clear now?
Rich
It is certainly somewhat clearer. I think the confusion stems from a poorly-specified analysis. Are you comparing the temporary use of a sample roaster prior to acquiring a larger roaster or are you analyzing the ongoing cost savings associated with using a smaller roaster and smaller batch sizes? If the former is the case, $6,000 is clearly the wrong figure against which to compare variable costs. If it is the latter, then the numbers add up, but then a key issue is the degree to which results from the sample roaster can be translated to the larger roaster.
I would recommend laying out your assumptions and the goals of your analysis, along with any non-standard definitions that are in your mind when you formulate your thoughts. This will make your posts much more useful.
- boar_d_laze
Thank you for your helpful advice.CoffeeMan9000 wrote:I would recommend laying out your assumptions and the goals of your analysis, along with any non-standard definitions that are in your mind when you formulate your thoughts. This will make your posts much more useful.
Rich
