Gaggia MDF - "absolute zero" - Page 2
Broken in. I couldnt get my v60 dialed and then after about 2 months my settings had to shift drastically and i got control...unless I was doing something wrong-i was also improving my pouring technique, but it seemed a pretty drastic shift.
A few days ago I change the coffee ( chiapas mexico ) for roasted blend here, very fresh, and another single origin from Peru. And thats the problem! I should have started around here, changing the coffee.
I guess that Mexico roast was very old, when i raised up the lever the coffee flow so quickly through the coffee cake.
Actually I had no problems with ground , even at level 2 if i tamp with great force i can choke machine. Now Its not necessary use the grinder so near to zero point. The burrs can run more freely now
At the moment I 'm taking the best shots from long ago.
Thanks for help! for the moment i will leave de stepless mod for the future.
Actually it might be the perfect time to get the stuff for it. You have a bean working well at step 2 and that may allow a bit of time to enjoy the pavoni while shopping for the necessary parts. No reason at all it should exceed 10 dollars, mine was just a couple of dollars, but finding something with the correct diameter opening that will offer enough resistance, or ordering the plug online, may take some time depending on availability. It will even help with pourover, but there is no doubt you will eventually need it for espresso.
Also, if you havent, it is critical imo to city off the finger gaurd and get some cheap antistatic brushes to clean out the old grinds from the chute.
I got something similar to this http://www.amazon.com/gp/aw/d/B00880BAJ ... d0_g328_i1
