Cimbali M21 Junior problem: green light blinks endlessly
Hi.
In the morning the machine is switched on automatically. When I approached it the yellow light was on, indicating missing water. I filled the water tank but since then the green light blinks endlessly and the machine stays cold.
I tried to switch off and on but it won't help.
Any Idea what is wrong with the machine?
Hi
I have a very similar issue today.
Did you find out, what problem your Junior had?
I really would appreciate your answer.
Torsten
Torsten
The owners manual says:
If that doesn't fix it, the manual also says "Machine cold, lamp (12) flashes. - Call service technician" I'd call someplace local (or find an online number) and see if they've heard of the problem before.
I don't have this machine, but my guess would be to check the safety thermostat? Check the Disassembly section.When the yellow indicator light (8) lights up, fill the reservoir up to the maximum level.
If this operation is delayed, the safety device is activated and the coffee preparation procedure suspended.
Well, the solution for the problem was to press the safety thermostat switch.
You were right.
Funny thing is that I'm running into the same problem now, 8 month later, and pressing the switch does not help. This time the machine was working properly when suddenly the green light started to blink and the yellow one was lit. Maybe I need to wait for the machine to cool down and only then press the switch ?!
You were right.
