Buying a Moka Pot - Page 5
- Lvx
Thanks, I know you, the "famous" doubleOsoul "doubleOsoul wrote:Very helpful, Lucio. By the way, I like your youtube videos (I'm the one who has been leaving comments).
- Lvx
Buy a new silicone gasketbmb wrote: The coffee flow from the stainless ones is steady and uniform, from the aluminum it's all burp and spit.
No other reason
- Lvx
The same valve is now installed on new Moka Bialetti. It's easier to check than the old style: just pull the pin to be sure it works well.SpromoSapiens wrote:, users apparently need a potholder to touch the handle to lift it off the burner. (at 2:40 in the linked vid)
That Pensofal just shot to the top of my list, thanks for that link. Shame it only seems to come in black + branding. Can someone explain the difference in valves, i.e. the Bialetti standard vs the Pensofal "Inspection valve for better temperature control and safety?"
- Lvx
My good morning moka is the "Squisita" http://www.ilpiaceredelcaffe.it/Templat ... getto=3047
I use it daily since 2010 http://caffettiere.blogspot.it/2010/02/ ... parte.html
http://caffettiere.blogspot.it/2010/07/ ... parte.html
The only issue is the overall higher temperature at the end of the extraction (73°C vs 65°C with the Bialetti). I have the 4 cups, maybe 2 cups has the perfect height.
But I love it. Strong, fast, easy to clean (you remove all scale in the lower chamber ... with your finger!).
- SpromoSapiens (original poster)
Sadly the Squisita is apparently not available in the States.
Also I notice the Pensofal gets terrible marks on Amazon.it, as people say it is not actually effective on induction. Or so I deduce from the remnants of my Italian skills. Is there some other benefit to the combined steel/alu bottom? I do like the heat-absorbing extra width.
What might be the benefits of Teflon in a moka pot?
For closure:
After much agonizing, inquiring, and eBay-lurking, I wound up back where I started, at the simplest, cheapest, most obvious option. A plain old brand-new aluminum 3-cup Bialetti Moka Express is on its way. So many generations of Italians + Dr. Gary can't be wrong. If I really fall in love, then maybe I'll revisit the stainless or ceramic ideas.
- drgary
Good choice!
You'll get a kick out of this. Last week I walked into a Goodwill and found a brand new 6 cup Bialetti Moka Express for $13. There was no box and the lid was just slightly off alignment. It had never been used. I easily realigned the lid on its hinge. It'll probably be a gift to someone I'm introducing to coffee.
LMWDP#308
LMWDP#308
Of course you did. You were obviously not there specifically looking for one. Like love, the second you stop searching for it, there it is.drgary wrote:I walked into a Goodwill and found a brand new 6 cup Bialetti...
