Gaggia Gilda v1 driptray cover - Page 2
- zeb
A pleasure to see you there Dominique
Don't you think the thickness is 1mm ? 0,1mm seems an usual thickness for nickel and then chrome plating no ?
Kaldi61, do you still need a 1:1 scale scan or the picture is enough ?
- Yoombe
hi Pascal, pleasure is mine. I did not have original part in hand, I can not confirm thickness. I had some old 1.5 mm
brass sheet and I did not want to buy a new one... But 1mm could fit too.
- kaldi61 (original poster)
These pictures should be enough, thank you very much.
My plan:
1.2 mm brass sheet.
I will prepare a jig to clamp several together and drill holes.
Then last step is to cut the rounds out from the sheets.
Then send for chrome.
Thinking it over, I think it best to drill the 131 holes prior to cutting the rounds out.
I will let you know how it goes. It will be some weeks until I can work on it - my Faemina is on the way, and that is first in line.
thanks,
My plan:
1.2 mm brass sheet.
thanks,
-Nelson
LMWDP #506 "It's not just for breakfast anymore."
- crazy4espresso
Looking forward to seeing the result. We don't get very many Gilda posts. Post a pic of the old Gal.
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
