Espresso machine pump making weird sound... any thougths?
my espresso machine has a 110v procon pump attached to a motor. It was working fine and today when I turned it on to make a latte I turned on the brew switch and the motor made a quieter hum rather than its usually noisy sound. The water didnt seem to come out as strong and the machine got quieter the longer I experimented. I know something is wrong I just dont know what...is it the pump? the pump motor? What can I check and how can I check it? Im prepared to rip the machine apart If I need to
- cannonfodder
First thing I would check is your pump pressure. Has it dropped, second would be water pressure. The pump pressure is dependent on the input pressure unless you have a balance bypass pump. If you mains pressure drops, your pump pressure drops with it.
well, I dont have a pump pressure gauge on the machine. the line in pressure has not changed, I have it on a flo-jet from a 5 gallon water bottle.
How can I check the pressure of the pump to the portafilter?
- cannonfodder
The Procon is s a rotary vane pump?
My rotary vane pump started making noises but it was actually an issue with the no-return valve; hot water flowing back into the pump.
Open the machine up, check if it's getting hot, take some video and share it.
alright, ill tear into ol' bessy and post an update soon. Thanks guys!
