Wiring diagram for KitchenAid Proline espresso machine
- PacMan
Just picked up a used Kitchenaid proline espresso maker at a "I had to do it" price. Cleaned it up, ordered the appropriate missing parts and now I'm ready to add the typical Gaggia Classic mods (pid, silvia steam wand, pre heat coil). The one thing I'm trying work through now is how the chip and relay inside determines which of the two boilers to send current to and if I could set up the PID as I did on my classic without having any issues. There are a few descriptions of this being done but nothing detailed so I figured I'd try a few things and see which worked best. Before I pull out the multimeter and start tracing everything again I wanted to see if anyone had a source for the wiring diagrams that I could use as a starting point. Thanks.
See if this helps
http://www.gaggiausersgroup.com/index.p ... =page;p=38
- pizzaman383
- Supporter ❤
These pictures show how I hooked up my PID.
https://plus.google.com/photos/11355936 ... 6602275073
Curtis
LMWDP #551
LMWDP #551
- PacMan (original poster)
Thanks. I did run across your posts over at gaggia user group.
From a functional standpoint, does power go to both the steam boiler and the brew boiler at the same time? Or, does the relay still dictate which boiler gets power.
Can you tell me what I need to do to get the Silvia steam wand to install easily on the KitchenAid? I bought one awhile ago to put on my KitchenAid but it's not fitting together securely so I went back to the original steam wand arm in the meantime.
- pizzaman383
- Supporter ❤
Those pictures cover where to put the PID into the brew boiler wiring. The relay dictates which boiler gets power. I rerouted the wiring feeding the steam boiler so that it bypasses the relay entirely. I only use the steam boiler infrequently so I put in a switch that keeps the steam boiler off except when I want steam.PacMan wrote:From a functional standpoint, does power go to both the steam boiler and the brew boiler at the same time? Or, does the relay still dictate which boiler gets power.
Curtis
LMWDP #551
LMWDP #551
