ECM Giotto Classic loses boiler pressure
I have a 2003 Giotto Classic, which after about 45 minutes loses pressure. A sharp rap on the side of the machine restores operation for about 15 minutes. Thinking it was due to a mechanical relay, I replaced the heater relay RL3, with no effect. Is there an element on the controller board which more commonly fails as it heats up?
Thanks for your help.
- Randy G.
That sounds more like a problem with the pressurestat contacts staying open. That could be a pressurestat problem itself or possibly scale in the line not allowing the pressurestat to close its contacts or a bad diaphragm. Something like that.
- cuppajoe
Could also be the vacuum valve or safety pressure release valve sticking slightly open. A small mirror held next to valves and fitting will show any 'ghost' leaks.
David - LMWDP 448
- cuppajoe
PS - What I found with the La Cimbali Junior is that overfilling the boiler will sometimes cause the vacuum valve to leak a bit until the level drops.
David - LMWDP 448
- Iskanda
What happens if you open the steam valve for some seconds after 30 minutes? The same ?
- homeburrero
I have a 2002 ECM Giotto, which may or may not be like yours. I understand that back then they came out of the factory with a little variability.
Be sure to check that your reservoir sensor probe is making good contact. Even when the reservoir is full, a poor contact will cause your symptom - green light on, no heat, and if you actuate the lever, no pump. And a rap on the machine will often wake it back up for a while.
You can clean this contact:
Also to test, you can temporarily remove the reservoir sensor wire under this contact (pictured below), then reattach somewhere to a good ground and see if that fixes it.
*Edit: I originally slightly misremembered my machine's age. Checked and it's 2002 not 2003 (SN# 20020402109) Mine has the GiCAR 9.9.04.77G, which feeds low current through the pStat and has an internal heater relay (R1).
Pat
- benpiff
I eventually had to have my Giotto pressurestat and high limit replaced. So I guess my situation was different, had to poke the red button to get the machine to turn back on.
