TJ-067 Gas Roaster Guidelines for Different Load Sizes - Page 14
- JK
I wanted to add something I noticed roasting today..
I installed a MET Probe a few roasts back and read Temps should stay below 450*
Anyway I noticed while increasing air after drying my ROR stated gaining so fan was not high enough and had more heat stored in burner chamber than air was pushing out..
I see my low fan speed should be higher than slowest speed so chamber is not warming more than air is removing..
Is this theory right or am I missing something..
Air pushes out as much heat as burner adds, not burner chamber gets hotter and heat increases when more fan is added....
I'm on a Mission from God!
- drgary (original poster)
My experience is similar with perforated drum but less fan is needed than you describe.
LMWDP#308
LMWDP#308
- JK
I think if air/gas is set right your ROR will not rise if fan is increased.. IMHO it will stay the same or lower..
