Drum Temperature to Start Out the Roast
Hey guys,
I have a Huky 500 on the way and can't wait to get started with the roasting. Couple of quick questions:
What temperature do you bring the drum to before you drop in the green beans?
Do you have a target rate of rise?
Looking forward to experimenting with different roast profiles.
Blake
Blake
- hankua
200*C works for a start; I turn the gas down low after that. Then up high after the turn 80-100*C @1:30. Then slowly taper the gas down during the rest of the roast. (This is using the stock IR stove w/regulator and 1lb green coffee)
I'm just some ten or so roasts ahead of you and I found great advice (especially KFir's answer) in this thread: Learning my Huky 500.
You will note that KFirs starting temp are a bit higher (230-280C, depending on load size). I recon it's more about personal preferences, i.e. how much leeway do you want in shaping the rest of the profile.
Anyhow, you will have great fun, at least I have.
- cygnusx1
Your charge temp will vary based on the weight of the charge. Since I roast 8oz batches, I'll charge at around 300F depending on conditions. I usually reduce the heat at charge to 10% then increase to around 40% at TP. I like to get around a 4-5 minute drying phase then go full blast.
But again the start temp definitely will depend on the weight of your charge.
- bean2friends
Using the perforated drum and the BT probe and the stock stove with lpg, Kfir's temps work very well for me.
- hankua
Post a pic. when you get it set up. My first Huky roast hit 1C in 6 min. using Mr. Li's starting temp.
It's good to find the extreme edges of roast parameter to establish your comfort zone.
- cannonfodder
I have a different roaster with a solid 1/8 thick drum. I let it preheat for about 15-20min and overshoot my charge temp by 50 degrees. Then back the gas down and let the system stabilize at 400-450F depending on the charge amount and bean. Then charge the drum, no gas change. I will make very small damper adjustments to regulate the gas flow up to near first crack (provided I am happy with the rate of rise).
Thanks everyone for getting back to me.
