Bezzera Strega switchable tank/direct connect or tank only
There is a $200 difference between the Bezzera Strega "switchable tank / direct connect, vibration pump" and the "tank, vibration pump". Aside from the direct connect feature, are there other differences? Can the "tank, vibration pump" version be modified using the guides in this forum such as "Vacuum Relief Valve Drain Line Modification" and "Rotary Dimmer Switch Mod for the Vibe Pump"? Can it be modified easily to plumbed and within (or close) to $200 in parts? What's your recommendation/advice? I am not sure if I would/should plumbed it.
Thanks,
Clark
Thanks,
Clark
- JohnB.
I came up with both of those mods before the switchable TOP model was even available & I'd say that the tank model could be plumbed in for much less then $200.frenz610 wrote:Aside from the direct connect feature, are there other differences? Can the "tank, vibration pump" version be modified using the guides in this forum such as "Vacuum Relief Valve Drain Line Modification" and "Rotary Dimmer Switch Mod for the Vibe Pump"? Can it be modified easily to plumbed and within (or close) to $200 in parts? .
LMWDP 267
Great! I'll buy the cheaper tank only model and will plan to do the mods after few months of use. Thanks John!
- LDT
John can you direct me to information on how to do the dimmer switch mod on the vibe pump? Thanks
- TomC
Step by step with photos.
The Super Strega: Modifying preinfusion pressures and other functional improvements
Gratitude goes to John who walked me thru it. I put it in pictures so visual learners like myself could make sense of it.
