Used Elektra Semiautomatica and grinder
I'm a newbie and have come across an Elektra Semiautomatica at roughly half off retail. It looks to be in good shape. Two questions: (1) What should I look for when I inspect the machine - recognizing I know very little about the mechanical operations of these machines and (2) and the proverbial question on grinders. I'd like to spend $400 or less. Thanks!
At $400 or less you are limited to a hand grinder. If that doesn't suit you then you have to spend slightly more for a Baratza Vario, unless you can find a used Super Jolly. I have found grinders in that range that are worth having, but you have to wait a while for them to show up sometimes.
When you check a machine you should ensure its clean, works, and not damaged (dents, corrosion, rust, ect.). Semiautomatica is a machine with a pump. This makes it more complicated, so you should pay attention to the electrical as well as the plumbing.
LMWDP #366
The elektra semi-automatica is one sexy machine. Unfortunately, I am one to go for form over function so the semi-automatica is the only machine I would have considered as a replacement for my pavoni based on my aesthetic taste.
The reason I decided to stay with my machine was that the semi-automatica seems unreliable based on the account of one poster who had to keep the semi-automatica in the shop several times over the span of a few years - for problems like boiler, pstat replacement etc..
I tried to do further research on the reliability of the semi-automatica but there isn't much information. Let me know if you find any information stating otherwise.
- drgary
Elektra's a long-established, quality manufacturer. Replacing or rebuilding a PSTAT is a periodic chore that happens on most machines, and replacing one is easy and cheap if you need to do that. The Semi-Automatica got a great review here by Jim Schulman.
/elektra-se ... eview.html
LMWDP#308
LMWDP#308
