Propane lever espresso machines
Does someone have a list of available propane lever machines that can also be run on 110v?
I don't have a list, but I do have a propane burner for my 110V two group Rancilio Z9 from 1979 or so.
-phillip
-phillip
- drgary
Also no list but Conti makes a lever that can be gas or electric. I don't know if it could be both. This machine still uses their terrific Prestina group.
http://www.conti-espresso.com/produit/cc100_pm
LMWDP#308
LMWDP#308
If you're talking about a lever machine that can be run with a 110v heating coil and a propane burner at the same time..... I've no clue....
But there's always a method to retrofit a heating coil into an existing propane system....
It could be as complex or as simple as you want. It's the choice of the barista.
Thanks. I won't be using both electricity and propane to heat at same time. I would be using where there may not be enough power at times and sometimes it would be used where there is plenty of juice.
Any idea what that Conti 100pm would cost in a 2 group?
As long as you are considering a 2 group, it would be worth your time to ask Astoria, they have all the parts to make a 110V and gas fired lever. It would undoubtedly be a special order, but given their willingness to make raised group machines I think they might be amenable. You might also want to inquire at Quality Espresso, the folks that make Futurmat, Italcrem and Visacrem. They made 110V 2 groups in the past, and they still make levers (although I believe they no longer market levers in the US.)
