My friends Expobar Leva1 problem
jagobear
#1: Post by jagobear »
The e61 group head connect to the body,there are pad, but it is moved,is it a great problem?
Leakages, and pressure loss?
Randy G.
#2: Post by Randy G. »
The group is secured from inside the case with two screws. That cork is just to isolate the group from the case for vibrations. It is not a water seal. Open case, loosen screws (may be bolts), arrange gasket, tighten screws. Done.
