Replacing the heating element in Quickmill Anita
wy100101
#1: Post by wy100101 »
One of the wires to the boiler heating element melted last week, and after a bit of back and forth with the services guys at Chris Coffee, I have a replacement heating element on the way. I popped open the case and had a look around, and I'm not sure what the right way is to replace the heating element.
I didn't find anyone talking about doing it online, and I was wondering if anyone could point me at a step-by-step or could explain it to me at least? Any help would be appreciated.
thanks,
--Matt
erics
Supporter ★
#2: Post by erics »
Set the machine upside down on a soft surface.
Rotate the access plate out of the way.
Use a 1-1/2" deep socket and a tee-handle wrench to unscrew the element.
Alternatively, take the machine to your favorite auto mechanic and let him remove the element with an ADJUSTABLE impact wrench.
Skål,
Eric S.
http://users.rcn.com/erics/
E-mail: erics at rcn dot com
Advertisement
wy100101 (original poster)
#3: Post by wy100101 (original poster) »
Thanks, I didn't realize there was an access panel for that. I'll give it a look.
--Matt
erics
Supporter ★
#4: Post by erics »
Depending on where you are in California, it may be a good idea to take the machine here: http://www.greatinfusions.com/ . This should NOT be considered a trivial task, especially when doing it for the first time.
I assume you also ordered a replacement seal for the heating element.
Skål,
Eric S.
beta14ok
#5: Post by beta14ok »
Not quite the same thing as your Anita, but I imagine the process is similar....and yes, it was a little scary my first time as there is a lot of damage that could happen.
Check-out:
Boiler Heating Element Replacement - Isomac Mondiale
#6: Post by wy100101 (original poster) »
Yes, I've ordered the parts already. I've been busy, and haven't opened the panel to take a look yet. Santa Cruz isn't too much of a hike, but I was hoping, I could do the work myself.
I'm toying with the idea of upgrading, but I wanted to see how well I could do the maintenance on the Anita myself first. Minimally, I was hoping to buy some time for shopping for the upgrade. We are in serious espresso withdrawal around here right now. :)
Thanks for the help guys,
-- Matt
adagio
#7: Post by adagio »
Did you end up doing the work yourself? How would you rate the difficulty of attempting such repair.
Thanks,
