Replacement burrs for Caramali/La Pavoni Zip/Obel, etc
I was about to push the buy botton on a new set of burrs, which I assume would be a good idea as I've had to adjust it finer and finer in the past year or so (does the wear accelerate that way?). My real question is whether there's a set of compatible burrs made of some better, newer material that I should seek out? (Espresso Parts says the burrs are 64mm x 38mm x 9mm, left hand rotation.) Thanks!
La Marzocco Swift Burrs fit your spec and are ceramic. Praise has been heaped on this material in terms of longevity and in the cup nuances.
Thanks! I thought the Swifts were 64mm. I'll have to look more closely.
