Conti Prestina, The Netherlands - Page 9
LS,
After a couple of months (and daily use) I can say that the machine works flawless, but steaming milk is a real PITA (and getting a bit annoying).
The machine has a lot of steaming power and a very slim steam wand with a fixed four-hole steamtip (which cannot be unscrewed). I have considered shutting two (or three holes) with the disadvantage that it will be permanent...
Who can assist me with some advice?
Many thanks, TY
Many thanks, TY
- Bluecold
LMWDP #232
- Paul_Pratt
Your best bet will be to change the entire wand so that way you can put on any steam tip you like, most these days have an M10 fine thread. I had a quick look through the thread and it seems like your end fitting is a 3/8 BSP. A suitable candidate would be something like a Faema or VBM steam wand, right hand side.
This is actually a very good suggestion. The wand of a Fiorenzato Ducale may be promising.
http://www.espressoxxl.de/shop/artikel/ ... etail.html
I will provide an update.
Cheers, TY
Cheers, TY
- drgary
I have found that mine steams quite well with the stock tip. It's very powerful too. I don't try to swirl the milk but work to get a standing wave. What technique have you been using?
LMWDP#308
LMWDP#308
My technique? I put the steam tip just below the surface of the (cold) milk. Try to generate a slurpy sound without creating big bubbles. Sometimes I get great microfoam, but most of the times I fail because of limited time.drgary wrote:I have found that mine steams quite well with the stock tip. It's very powerful too. I don't try to swirl the milk but work to get a standing wave. What technique have you been using?
I tried this suggestion, but makes it even more difficult...Bluecold wrote:Toothpicks?
Cheers, TY
- drgary
This is a machine with commercial steaming power, so it should steam very fast without worries about running out of time. I think you're using technique for a home machine without that power. With mine I don't try to incorporate air. Instead I immerse the tip deeper so the steam wand does all the work of creating microfoam. I also don't try to swirl the milk. I let it set up a standing wave. This may solve your problem.turboyeast wrote:My technique? I put the steam tip just below the surface of the (cold) milk. Try to generate a slurpy sound without creating big bubbles. Sometimes I get great microfoam, but most of the times I fail because of limited time.
LMWDP#308
LMWDP#308
Please take some video of her running. Love to see a shot.
Beautiful
Beautiful
LS,
With some reluctance I closed three of the holes in the steamtip (with toothpicks) as advised by Bluecold. Steaming is now much much better...there is more time to slurp the milk and the microfoam is great. If -for some reason- I wanted to open the holes again, I would have to drill the toothpicks out and remove the steamwand accordingly to purge the remains. I hope this won't be necessary. Enjoying microfoam and thanks for the advice!
Cheers, TY
Cheers, TY
At your service (sorry for my blabbering kids who are disrupting my video)...Espresso_Monkey wrote:Please take some video of her running. Love to see a shot.
Beautiful
LS,
Inspired by a "colleague" I have used an amprobe in combination with artisan, to thermo-characterize my Conti prestina in a bit more detail. The machine uses a 1200 watt element to heat up the boiler. The boiler is insulated with armaflex and the pstat is set at 0.8 bar. In my case ET stands for boiler temperature and BT stands for group temperature (measured just below the stainless steel box). The boiler is at pressure after 25 minutes and starts a nice cycle afterwards. Delta time is approx 2 minutes cooling and approx 35 secs heating. Delta temperature is approx 2 degrees Celsius.
It is obvious that it would take a long, long time before the group is heat-saturated. My guestimate at this time: at least an hour. I have attempted to ramp the temperature a bit with an open port flush. This is very doable and it greatly shortens warm-up time. Before doing these measurements it was an absolute shot in the dark how long to do an open port flush and at which flow. Under my conditions the group is at approx 73 degrees Celsius when heat-saturated. When pulling a shot the group temperature increases 3 degrees Celsius. It takes about 5 minutes to recover, which is a bit long?
These are just some crude experiments. I am aiming to do some finetuning. It would be nice to develop some kind of benchmark for machines. A cheap machine will definitely perform differently in temperature behavior as compared to a expensive machine. Final observation: although the boiler goes into a cycle, this cannot be observed for the group which is basically a flat-line under idle conditions.
Cheers, TY
Cheers, TY
