Replacement Faema Faemina steam wand? - Page 2
- Coffeecritter (original poster)
Good news - Julius has the steam wand and will send one to me. Thank you, Marcel, for the suggestion.
Sue
Sue
Life's too short to live in Dallas!
LMWDP #157
LMWDP #157
- yakster
I wonder if something like this Hispano Suiza M12-1.0 Compression Nut could be used to attach a steam wand to the Faemina. It's a brass compression nut with M12-1.0 thread and a 6 mm hole. It would be interesting if this could be used (with the hole possibly drilled out) with an existing articulating steam wand kit.Paul_Pratt wrote:Well there is a snag. It seems the pipe nut that should be 1/4 bspp is actually not. It would seem to be either an M12 x 1.0mm. Never comes across this before so it will need more time and will involve sourcing a tap and making custom end pipe nuts. The steam tip fittings are also metric M10 x 1.0mm so it is possible that it is M12 x 1.0mm, I will have to measure properly to see the correct size, but the threads are 1.0mm.
-Chris
LMWDP # 272
LMWDP # 272
- yakster
The threads are 1.0, my thread sizer came in, but the pipe nut appears to be M11 M12 x 1.0 and the steam tip fitting M8 x 1.0. I'm still waiting for my nut sizer to come in to confirm this and still trying to find parts to make my own longer steam wand.Paul_Pratt wrote:Well there is a snag. It seems the pipe nut that should be 1/4 bspp is actually not. It would seem to be either an M12 x 1.0mm. Never comes across this before so it will need more time and will involve sourcing a tap and making custom end pipe nuts. The steam tip fittings are also metric M10 x 1.0mm so it is possible that it is M12 x 1.0mm, I will have to measure properly to see the correct size, but the threads are 1.0mm.
-Chris
LMWDP # 272
LMWDP # 272
- yakster
My bolt sizer came in and the pipe nut fitting is really a M12 x 1.0 and the steam tip is an M8 x 1.0. Still appears to be not that common a size.yakster wrote:The threads are 1.0, my thread sizer came in, but the pipe nut appears to be M11 x 1.0 and the steam tip fitting M8 x 1.0. I'm still waiting for my nut sizer to come in to confirm this and still trying to find parts to make my own longer steam wand.
-Chris
LMWDP # 272
LMWDP # 272
- cuppajoe
Wondering if anyone might know of aftermarket tips that could be re-tapped to M8 x 1.0. An Espro Toroid frothing jug helped a lot using the stock tip with two holes plugged, but still not completely happy with it.
David - LMWDP 448
