Bubbly crema
Dear GS3 users
I had a little bit worries to post this new topic, since I am quite an advanced barista, ,
but actually I don't know if it is a GS3 problem or not, thus I thought to share it with you guys.
Since approx 3 month I am observing that I get decent bubbles on the crema on espresso shots.
What have changed since my observation was the new Brita filter which I had before too (annual change & properly rinsed 10L)
Interesting is, that it is not always the same and I observe that it is more linked to lighter roasted coffee.
I normally extract at 93.5°C and brew pressure on the gauge is set at slightly behind 9bar (machine is plumbed to mains). The coffee I am currently using is 30 days old, so it rested quite good.
Could it be there is a restriction in the water flow in order the water jet is coming too fast to the shower screen? Gicleur? I also observe that there is sometimes a kind of whistling sound after the first 10sec.
other details: shower screen IMS MA 200 IM, basket VST20 , dose normally 20g and 34-38 shot weight.
thanks for some hints and best regards
streezz
streezz
- cannonfodder
There is your problem. Old coffee. Try something no older than 14 days, 5 days would be better.streezz wrote:The coffee I am currently using is 30 days old, so it rested quite good.
<image>
- Stereo Heathen
This looks normal to me.
Isn't it just the nature of using a bottomless portafilter? Unless you do something to collapse the crema, such as running the stream down the side of the cup.
If I use the bottomless portafilter I always get bubbles because the espresso drops from pretty high up. When I raise the cup to close the gap then the bubbles disapear. Using a spouted portafilter and rainsing the cup completely eleminates the bubbles. Nothing to worry about.
