Elektra Semiautomatica boiler not filling - Page 2
I went ahead and lowered it to the lowest setting, but there was no change. The gauge went up past the green zone and I shut it off before it hit the red. At no point did the ready light shut off.
Any other ideas?
Thanks.
Any other ideas?
Thanks.
- erics
- Supporter ★
You are turning the small screw CLOCKWISE to lower the pressure ?
If so, I can only think of two faulty items: the new pressurestat or the installed pressure gauge. I would suggest you assemble a secondary gauge and attach it to the steam wand using flex hose and screw clamps.
Update!
I found the problem. Before sinking anymore money into this machine I decided to tear it apart and double check that everything was working properly. Everything was perfect... Until I removed the pressure gauge. There was what looked like a rock of something lodged in it. I used a tooth pick to remove it, and now everything is working normally again.
Thank you Eric and everyone else who helped!
