Huky 500 propane tank / hoses?
- stuart1927
For the Huky owners out there using the IR burner. Which propane bottles are you using and what size hose and fittings are these generally compatible with?
Many thanks
sbb
Many thanks
sbb
- LDT
Stuart,
I purchased a 20 lb. propane tank from Home Depot and used the regulator and hose with attached fittings as supplied by Mr. Li. I wish I had quick disconnect capability, but they may be more prone to leaking - I really don't know. This is all I can tell you.
Similar to the Home Depot tank I got a Blue Rhino 15 lb tank at Lowes. I must have 50 roasts done and the tank still reads 3/4 full. I also use the hardware that came with the stock IR stove and roaster.
