Roast color seems to develop very early. What could cause this?
Split off of discussion Ethiopia DP Gr. 1 Yirga Cheffe Aricha-Current crop at Sweet Maria's)
Laron,
You bring up a point that has been rather confusing to me, as well.
Color on all my roast seems to develop very early. By the time 1C starts, it already looks like a C+ level.
Anyone have any ideas what would cause this phenomenon? All other guideposts seem to be in order and I really use a minimum of burner. Color development in the cross-section of the bean is even, which would appear to disproved any early external over-development. But I'm quite new to all this and am willing to learn how to improve my roasting knowledge.
At any rate, took a sniff from the bag this morning and I'm getting excited! Did you ever post your impressions of those 3 roast?
...split from Ethiopia DP Gr. 1 Yirga Cheffe Aricha-Current crop at Sweet Maria's by moderator...
Laron,
I recently had an experience with a coffee I purchased that was city+ on the outside, but not quite so on the inside.
I can't help but think that the drop temp was too high at the beginning of the roast. My best home roasts are when I don't see chaff for a good long while.
- LDT
Bryan, Regarding the photo, was that from the first batch or the second?
Rob,
You make a good point, as well. But I don't feel my charge temps are particularly extreme. Between 300-350F.
Sure, it stands to reason that if you progress very quickly through the whole process, you will end up with a disparity between the exterior/interior. I actually make a habit of slicing beans to check how evenly developed the roasts end and this was no exception. Same color all the way through. Likely due to my +13min roast.
Laron,
It was from the first. With on 3-4 degrees difference in drop temp, they are extremely close in external color:
Left: Roast 2 (shorter overall roast, steeper ramp) Right: Roast 1 (longer roast, slightly lower drop temp)
It's not killing me, but I would love to work to be able to understand the process better.
Laron,
