Wega Lyra with rotary pump rebuild question
I have a Wega Lyra with a rotary pump. The pump leaked water into the motor's bearings and the motor seized up. I was able to break it free and lubricate it, but it is loud and will probably seize up again.
The motor is the 100 Watt, 110 Volt RPM STA model. I will upload pictures in a subsequent post.
Has anyone rebuilt this motor? If so, do you know what size bearings to purchase? I would like to swap out the bearings but I am not sure what size bearings to purchase without taking it apart.
Thank you for your help!
Rebuilt the motor successfully this week. The motor takes "6202z" bearings they are 15mm x 35mm. The bearings on the motor use a sleeve that has to be transferred to the new bearings to fit the 13mm motor drive shaft.
