HG One RAW - For those who like it "Shiny" - Page 4
- Terranova
- Supporter ❤
Electrical conductivity is just one part of getting the ions neutralized.weebit_nutty wrote:Science ions flow through metals but not plastic.
Also plastic, glass, Teflon will be effected.
It all depends to their distance between positively charged or negatively.
The wider on the list, the more PITA.
http://en.m.wikipedia.org/wiki/Triboelectric_effect
With my pad under the tumbler or stainless cup, I am not seeing any noticeable difference in static - but I use two drops RDT, so that trumps all! I have gotten in the RDT habit since it works so well... if it ain't broke....
BTW, I have gotten a little more out of Scott's earlier rec of washing the funnel with soap and water (might have been in another thread) - can't explain it - but it gave that extra 10% push and seems to get the final cling-ons...
If I could just like crappy coffee again, it would sure save a lot of time and money!
This looks pretty now, until it starts oxidizing.
You would have to get it to near mirror finish, then constantly polish it.
Not to mention every time you touch it the oil in your hands will corrode it.
If not wiped off potential for permanent finger prints.
- yakster
Perhaps the "shiny ring" that weebit_nutty reports under the blind tumbler is inadvertently removed anodization resulting in higher conductivity than you'd normally see with anodized parts.Eastsideloco wrote:Right, but as long as the anodized coatings are intact, the parts are probably more electrically isolated than you think... If the equipment grounding hardware does not pierce this anodized coating, the technician needs to manually remove the anodization at the equipment ground locations. Otherwise, the anodized coating gets in the way of an electrical bond.
weebit_nutty wrote:BTW, speaking of shiny, the spot underneath the grinder where my blind tumbler sits is beginning to form a shiny ring
-Chris
LMWDP # 272
LMWDP # 272
- weebit_nutty
Craig said he planned to clear it after the polish.insatiableOne wrote:This looks pretty now, until it starts oxidizing.
- weebit_nutty
I am beginning to think it's not continuity that's the problem but air flow that dictates the dynamics of the charged ion particles. Most antistatic systems in industry use air pressure to blow negatively charged ions to neutralize static problem areas.yakster wrote:Perhaps the "shiny ring" that weebit_nutty reports under the blind tumbler is inadvertently removed anodization resulting in higher conductivity than you'd normally see with anodized parts.
This can be tested by masking only the contact area of the metal tumbler and see what happens...
- weebit_nutty
BTW on the standard HG One, what would you call the raw a AL areas texture? Bead blasted?
