Water in steam pressure gauge - La Marzocco GS3
- Italyhound
It looks like a leaking Bourdon tube. Did you check connections inside to be sure nothing is loose allowing water to condense in there? If all is tight then must be a faulty gauge. Although it appears the gauge is working?
Let us know!
Let us know!
- shadowfax
I bet this guess is right. I think it'd be pretty hard to get that much water into the gauge any other way. I'd also say that the gauge ought to still work, as long as the leak is very small, so that isn't necessarily a surprise.Derekb wrote:It looks like a leaking Bourdon tube [...] Although it appears the gauge is working?
You can actually remove that gauge's faceplate without too much trouble, from what I recall. You just have to take the gauge out of the mount and the metal ring around the faceplate slides off. It's probably been 3 years since I did this-I took mine off because there was some debris on the back side of the gauge glass. So you can pull off the faceplate and dry out the gauge and see if the problem goes away, but I'd guess the only real solution is replacement.
Nicholas Lundgaard
- Mayhem
The pressure gauge on my Linea started leaking maybe a year ago. There were steam and condensation underneath the glass, and on the inside of the machine water was dripping out into an increasingly large puddle. Ended up replacing the whole gauge as that seemed like the simplest solution.
Too much is not enough
- Italyhound (original poster)
Simple indeed. All done.Mayhem wrote:Ended up replacing the whole gauge as that seemed like the simplest solution.
