Versalab burrs for non-espresso grinding? - Page 2
- Terranova
- Supporter ❤
Yes, it just sounds a bit different.FotonDrv wrote:Is that the OEM motor that you put the potentiometer into the circuitry?
- FotonDrv
Is the sound difference the cog belt?
- FotonDrv
Thanks
What is the burr rpm range?
- Terranova
- Supporter ❤
150-550 rpmFotonDrv wrote: What is the burr rpm range?
- FotonDrv
That is a pretty wide range!
Does it tend to overheat the OEM motor? Or the circuitry?
- Terranova
- Supporter ❤
I have been running the same system for years in my kitchen, no problem at all (so far)
- FotonDrv
Would you happen to have a wiring diagram?
