Delay in Grinding - Bad Starting Capacitor?
Hi Grinder Gurus;
My current grinder is a La San Marco 90 purchased used. It has a manual doser and I am pleased with the grind uniformity; when it came home I cleaned it up and put it to work.
When I turn the power on, there is a delay - seems like forever but in actual fact it is on the order of two seconds - between when the switch is turned on and when the grind starts.
In reading various postings in this forum, I suspect that the starting capacitor is failing and should be replaced. Does this sound about right? It is a quiet delay - no hum, no pop.
Thanks
PocoJoe
Thanks
PocoJoe
PocoJoe
Safety Third- First Roast, then Grind
Ok so it was not 2 seconds... it was 1.2 seconds....
PocoJoe
