Convert Mahlkönig K30 stepped to stepless
Hello,
I came across a good deal on a 'Expobar' (Mahlkönig) grind-on-demand stepped grinder and went ahead and bought it. It differs from the Vario in that it is stepped, rather than stepless. It is possible to hold the step-release out manually, but this obviously is not a solid solution to fine-tuning the grind. Does anyone know if it is possible to convert the Stepped K30 (ES) to stepless? If so, how would you do it?
Would appreciate any advice. Cheers!
- russel
You can buy the needed K30 Vario parts from Mahlkoenig, but it's more than just a replacement lid and is a costly change...
You could DIY something similar, having never done so I'm not sure what issues you might come across.
russel at anacidicandbitterbeverage dot com
Thanks for the reply.
I'll need to look into it a bit more, then.
Cheers!
Cheers!
Hi!
Nice catch of the K30!
You need the following parts:
Cover lid with adjustment knob
small parts set for the K0 Vario
2 rails (for clamping+distance)
This stuff is about €450,- in Europe, so not really a bargain. At your present setup each step changes your particle size with app. 12 µm...I never had a problem with dialing in with the ES
You can contact Mallkönig US for the part if you really want to do it.
Hey,
just saw that you are from Sweden....of course no need to contact Mahlkönig US then
- @3aan
Its not only the top but also the grind chamber is different.
LMWDP #377 @3aan
no, the inbuilt grinder with the grind chamber is the same. There are only to different versions in all of the K30's in the market
Thanks for that rundown of parts.
After having used the grinder a while, I'm realizing the stepless adjustment is not much of an issue, given my skill-level. It's definitely good to know that the option is there, should it become a concern, though. I'm still trying to reach better consistency with dosing, tamping and flushing once I've determined the best grinder setting, so can't say I can single out the steps of the grinder as being a dooming variable for good extractions at this point. Overall very happy with the K30.
Cheers for all the replies.
I'll keep you posted if I ever decide to do the conversion.
I have a stepped MACAP, and don't miss the step less ...
As I dose by weigh, for smaller adjustments, I only have to add or decrease 1/2 gram from the dose I'm using.
As a matter of fact, for me it's easier to dial-in this way as messing with the grinder, and use the same method also with the step less ones.
