Quick Mill QM67 Assembly Issues - Page 2
I'm a bit late now but thought I'd share my experience.Duffy5 wrote: On initial start up, the machine would not fill the boilers following the exact procedure as stated in the owner's manual. With telephone support, the tech thought maybe the boiler fill solenoid was not opening.
I had a similar issue with my QM Aquila Deluxe when I initially set it up and switched it on, the boiler would not fill. After verifying the power connections were good, my next thought was to check the reservoir low water float valve. After I emptied the tank, I noticed the float was stuck to the bottom so after wiggling it a bit I was able to get it loose. I refilled the tank and powered up the unit, then voila! the boiler began to fill up.
The unit has been working great ever since!
